Disables the generation and processing of BOOTP packets on a VLAN to obtain an IP address for the VLAN from a BOOTP server.
bootp | Disable BOOTP client. |
ipv4 | IPv4 client. (default) |
dhcp | Disable DHCP client. |
ipv6 | IPv6 client. |
vlan | Specify VLAN to configure BOOTP/DHCP client for. |
vlan | Specifies a VLAN name. |
all | Disables all VLANs. |
Disabled.
If the IPv4/IPv6 keyword is not specified, IPv4 is taken as default for the mentioned VLAN.
The following example disables the generation and processing of BOOTP packets on a VLAN named accounting:
disable bootp vlan accounting
The ipv4 and ipv6 keywords were added in ExtremeXOS 15.6.
